yasop
Nov 07, 2013Aspirant
How to do two 3g/4g modems connections in the same computer
How to do two 3g/4g modems connections in the same computer?
I have a 312U and a 306U, and i would like to do the two connections.
The Aircard Watcher only works with one modem at the same time.
I need another software to do the another connection?
Thank you very much.
- pinkbytesAspirantIt is not supported, watcher only supports one connection. Anyway why do you need to have 2 connections?
- yasopAspirantThank you for the reply! Because here, we are very limited in the bandwidth, i´m trying something like "3g bonding". It´s "wonderful" using 3g routers, but using it, i´m having low signal strenght problems.
- jmizoguchiVirtuosoIt would not work and will not bind two network to make it faster.
Maybe failover idea with two different cell data but that is not supported either :) - yasopAspirant"Connectify Dispatch" is a lie??? I can´t believe it...
- jmizoguchiVirtuosoNot sure what you mean..
