Binyamin
Apr 05, 2016Follower
How to enable telnet on VEGN2610
Hello All.
I have a Netgear genie VEGN2610.
I'm trying to enable telnet to my router, but nothing works.
I tried the telnetEnable (the old version over TCP and the new version over UDP), but both don't work.
These are the Telnet Enablers I have tried so far:
https://code.google.com/archive/p/netgear-telnetenable/
https://github.com/LuKePicci/NetgearTelnetEnable
Does anyone have any idea how to enable telnet? Or what could the problem be?
Thank you very much in advance!
Binyamin.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Binyamin
you will want to contact your ISP as they do the support for this modem.
DarrenM
