Adagraham's avatar
Adagraham
How to get Modem LB 1120 to turn to green light during setup?
During setup the power button lights orange and will not turn green. I have the sims card activated and everything will connect but has no internet connection. How would I get the power button to turn green Ive tried resetting it?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Mobile Routers, Hotspots & Modems
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
