OkieBobby
Mar 15, 2020Guide
How to get the unlock code prompt on AT&T Nighthawk MR1100
I have a AT&T Nighthawk MR1100 through OTR Mobile. They are switching to T-Mobile based service so I had to get the unlock code and a T-Mobile post paid SIM. When I put the T-Mobile SIM in and power i...
- Mar 17, 2020
If you can connect to T-Mobile network without entering the code, your device was unlocked.
Thanks
JohnPeng
Mar 16, 2020NETGEAR Expert
You need to contact AT&T or OTR Mobile to get the unlock code.
You can enter the code by visiting 192.168.1.1 and log in as admin.
Thanks
OkieBobby
Mar 16, 2020Guide
I already have the unlock code. My issue is I don’t get a prompt to enter it nor is their any place that is listed to enter it when I log on to the device management page.
- JohnPengMar 16, 2020NETGEAR Expert
You need to power on the device with T-Mobile SIM in order for you to enter the unlcok code.
Thanks
- OkieBobbyMar 16, 2020GuideI have done that and still get no prompt or anywhere to enter the code. Nothing when it powers on, nothing when I login to the device’s management page. Is it possible that it just happens to be unlocked already even though I was lead to believe it wasn’t?
- JohnPengMar 17, 2020NETGEAR Expert
Thanks
