OkieBobby
Mar 15, 2020Guide
How to get the unlock code prompt on AT&T Nighthawk MR1100
I have a AT&T Nighthawk MR1100 through OTR Mobile. They are switching to T-Mobile based service so I had to get the unlock code and a T-Mobile post paid SIM. When I put the T-Mobile SIM in and power i...
- Mar 17, 2020
If you can connect to T-Mobile network without entering the code, your device was unlocked.
Thanks
SandyJJ63
May 07, 2020Aspirant
Who gave you the unlock code? We tried AT&T and they are clueless. Did you get it from T-Mobile?
IIIGrimReaperII
May 07, 2020Tutor
Go to ATT.com/unlock I personally called ATT CS said i need to get my ATT branded netgear night hawk unlocked, gave my email address and a day or 2 later got a unlock code. BE WARNED with Covid-19 still going on ATT has reduced staff and pretty seems as tho they don't answer calls right now. Best if you can to use the automated route.
- GracieAllenMay 07, 2020Guide
That is sometimes a workable option IF you have an "ATT Branded" unit. As far as I know, for anything else, say a Nighthawk that's locked to AT&T but purchased from OTR Mobile, you're screwed. AT&T won't help.
- IIIGrimReaperIIMay 08, 2020Tutor
are you saying your nighthawk is not ATT branded, but locked to ATT??
Also if bought from OTR they will unlock it
