OkieBobby
Mar 15, 2020Guide
How to get the unlock code prompt on AT&T Nighthawk MR1100
I have a AT&T Nighthawk MR1100 through OTR Mobile. They are switching to T-Mobile based service so I had to get the unlock code and a T-Mobile post paid SIM. When I put the T-Mobile SIM in and power i...
- Mar 17, 2020
If you can connect to T-Mobile network without entering the code, your device was unlocked.
Thanks
IIIGrimReaperII
May 08, 2020Tutor
are you saying your nighthawk is not ATT branded, but locked to ATT??
SandyJJ63
May 11, 2020Aspirant
I'm not saying that, OTR said to call AT&T to unlock. That, of course, was not a good answer. Didn't work. OTR is sending another unlocked device and we should get it Wed. We will see. I will use dc-unlocker now that I know about it if I need to.
