OkieBobby
Mar 15, 2020Guide
How to get the unlock code prompt on AT&T Nighthawk MR1100
I have a AT&T Nighthawk MR1100 through OTR Mobile. They are switching to T-Mobile based service so I had to get the unlock code and a T-Mobile post paid SIM. When I put the T-Mobile SIM in and power i...
- Mar 17, 2020
If you can connect to T-Mobile network without entering the code, your device was unlocked.
Thanks
Ai01
May 13, 2020Guide
Rebooting MR1100 mobile router device via press and hold button does not work.
Instead do the following:
Reboot MR1100 mobile router device via router's settings.
- Go to Netgear's mobile router admin login page at 192.168.1.1 and login.
- Then go to the three dots at upper right corner of dashboard page. Click on it.
- A drop down menu will appear, click on 'Reboot', mobile router device will reboot successfully.
It will detect the change of a SIM card.
Robert8685
May 13, 2020Guide
Perhaps you should have read the discussion about the modem being locked! A hard reset does not have any affect on a locked modem recognizing another carriers SIM card.
