OkieBobby
Mar 15, 2020Guide
How to get the unlock code prompt on AT&T Nighthawk MR1100
I have a AT&T Nighthawk MR1100 through OTR Mobile. They are switching to T-Mobile based service so I had to get the unlock code and a T-Mobile post paid SIM. When I put the T-Mobile SIM in and power i...
- Mar 17, 2020
If you can connect to T-Mobile network without entering the code, your device was unlocked.
Thanks
GracieAllen
May 14, 2020Guide
Guys, you can keep posting that link to AT&T ad nauseum. IT'S NEVER GOING TO WORK FOR NIGHTHAWKS PURCHASED FROM OTR MOBILE.
According to AT&T, the numbers associated with those devices belonged to TELEPHONES and should never have been associated with hotspots. AT&T WILL NOT UNLOCK THEM.
OTR Mobile WILL NOT UNLOCK THEM.
Netgear WILL NOT UNLOCK THEM.
As far as I know, your choices are limited to dc-unlocker and some other company that purports to provide unlock codes for these devices.
I'm not sure what dc-unlocker is, but I found posts elsewhere that it's a group in Lithuania. To use them you have to go through some process of getting "credits", possibly some cyber currency, and whatever you give them is GONE whether they provide you with a successful unlock or not. There are LOTS of posts in various places from angry, frustrated people that WEREN'T successful getting unlocked by dc-unlocker. Others HAVE been successful. I haven't tried to unlock mine yet so I don't know if dc-unlocker is a total scam, a reliable company, or something in between.
Ai01
May 14, 2020Guide
Don't unlock with phone number!!!
Unlock using the IMEI number of the device only!!!
Do it yourself, might get blacklisted:
https://youtu.be/44tMF02pTv8
or
Buy AT&T Device Unlock from ebay 👍
or
