OkieBobby
Mar 15, 2020Guide
How to get the unlock code prompt on AT&T Nighthawk MR1100
I have a AT&T Nighthawk MR1100 through OTR Mobile. They are switching to T-Mobile based service so I had to get the unlock code and a T-Mobile post paid SIM. When I put the T-Mobile SIM in and power i...
- Mar 17, 2020
If you can connect to T-Mobile network without entering the code, your device was unlocked.
Thanks
Ai01
Jun 16, 2020Guide
If it's an unlocked netgear device then check signal if it's connected, check if Tmobile plan is active, or download Netgear Mobile App and reboot there.
If it's a AT&T locked device then go to the AT&T link below to unlock:
https://www.att.com/deviceunlock/#/
Use the web browser and go to 192.168.1.1, Or download and use Netgear Mobile app to reboot device. Then enter code.
