OkieBobby
Mar 15, 2020Guide
How to get the unlock code prompt on AT&T Nighthawk MR1100
I have a AT&T Nighthawk MR1100 through OTR Mobile. They are switching to T-Mobile based service so I had to get the unlock code and a T-Mobile post paid SIM. When I put the T-Mobile SIM in and power i...
- Mar 17, 2020
If you can connect to T-Mobile network without entering the code, your device was unlocked.
Thanks
Robert8685
Jun 10, 2020Guide
Update: Successfull unlocked.
After OTR mobile released the AT&T number associated with my MR1100, approximately 48 hours, the AT&T unlock portal accepted my request to unlock via IME number. Then 48 hours later it was approved and i was sent an unlock code and instructions. Putting in a new sim card shows the modem locked, access the MR1100 admin page gives me the option to enter an unlock code and submit and it was accepted. Unsure if one needs to do so every time the sim is changed or not.
No need to pay a third part many dollars to get software that will not even work as dc-unlocker.
Ai01
Jun 16, 2020Guide
AT&T UNLOCK Self Serve Portal page:
https://www.att.com/deviceunlock/#/
