cathyr
Oct 01, 2015Tutor
How to identify correct charger for AirCard 770S
Recently we were organizing power cords and I wound up looking at two NetGear chargers, both of which fit the AirCard 770S and now I don't know which is which. I looked at specs on the website but th...
DarrenM
Oct 02, 2015Sr. NETGEAR Moderator
Hello Cathyr
you should be fine using either one if they are charging the device did you look on chargers to see if they are different amps or volts? Hope to hear your feedback.
DarrenM
cathyr
Oct 12, 2015Tutor
Yeah I did and they are different (we had an older model and it had a charge the same shape and size but different amps and volts). Sorry I don't have them both with me atm, the one it is hooked up to now says 5.1V -- 850mA and is Motorola model number FMP5504A. If anyone else has the AirCard 770S and could check its charger against those numbers I'd sure appreciate it.
Thanks for responding.
