iMact3
Apr 04, 2018Aspirant
How to Install firmware for Aircard 782s
Hello! Is it impossible to reinstall the firmware for Aircard 782s via hard reset?
JasonN
Apr 04, 2018NETGEAR Employee Retired
Hi iMact3,
What do you mean by reinstalling the firmware? the most current firmware?
Please let me know. :]
- Jason N
iMact3
Apr 05, 2018Aspirant
My Aircard 782S has system problems and I want to reinstall the system.
- JasonNApr 05, 2018NETGEAR Employee Retired
Hi iMact3,
Can you please explain what system problems you're having? What provider model is your AC782s? trying to reinstall the current firmware or an older model?
- Jason N
- iMact3Apr 05, 2018Aspirant
I have Unlocked Netgear Aircard 782S (AC782S) and when I turn it on the device stock on BigPond logo. and when I remove the SIM card the device turn on and it work. so everytime before I turn the device on I should remove SIM card and wait until the device turned on to put SIM card again and sometimes the device switch off and on automatically.
I apologize for some mistakes in writing.
Hi iMact3,
It's fine! I can still understand.
Please proceed with a factory reset on your device.
Refer to the link below for steps:
Please let me know the outcome. :]
- Jason N
