h_ari
May 09, 2021Guide
How to port forward in Nighthawk M5?
I’m using a Nighthawk M5 (HW version 1.2) with a Netgear Orbi RBK33 mesh system. The Nighthawk’s WiFi coverage is not enough to cover the entire home so I need to use a separate mesh system. But unfo...
h_ari
May 10, 2021Guide
Looks like the problem is not with the Nighthawk modem or the Orbi router, rather the ISP I’m using. Apparently Telstra (over here in Australia) does not issue public IPs to their mobile broadband customers WTH?!?!?. :smileyfrustrated:
When I was going through the various settings of the Nighthawk I saw a 10.x.x.x IP listed as the public IP instead of the 1.115.x.x IP I was expecting to see as reported in my no-ip DDNS account and sites like whatismyipaddress.com !. I then googled and came across many threads like this one where other people have also complained about this exact same issue.
- icarusponyMay 10, 2021LuminaryThat's what I assumed at first, but I thought you had said it was previously working. I ruled out carrier grade NAT (which most cellular connections are restricted to). I thought you were one of the lucky few to actually get a live IP from a cell carrier or that you were paying them extra for a public IP.
