WalkerF
Nov 10, 2021Aspirant
How to setup VPN passthrough on Nighthawk m5
How can I configure VPN Passthrough on my Nighthawk M5 router? I see where to enable VPN Passthrough but there seems to be no way to input my VPN configuration. I am attaching a screen shot of [A...
JohnPeng
Nov 12, 2021NETGEAR Expert
For VPN passthrough, you also need to have the special subcription with VPN support from your carrier as we understand. Most of carriers don't allow incoming VPN access to your network behind M5.
Thanks
schumaku
Nov 12, 2021Guru - Experienced User
I am attaching a screen shot of [Advanced Settings / Other] where the VPN information should be.
Where do you see the M5 (a specific or any model SKU, data sheet, product description, ...) should have a VPN client on board?
Not sure about this - probably different in the States?
Incoming (VPN sessions established over the internet to the mobile router) require a public IP address on the router WAN/Internet interface. In the times of the shortage of public IPv4 addresses, we know that mobile providers usearrier Grade NAT, or are very often abuse private (RFC1918) address space. This is the primary feature our European carriers are enabling when booking a mobile connection for VPN connections.
