Mubarak7's avatar
Mubarak7
Follower
May 25, 2020
How to turn off updates on netgear 810S
Please help me . How to turn off updates on netgear 810S ?
  • Hi Mubarak7
    Welcome to NETGEAR Community!
    There is no an option to disable firmware updates on Aircard 810s. When an update is available then you will notified that there is an update available.The firmware auto-update right away if the update is deemed critical.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Mubarak7
    Blanca
    Community Team
