Cat1
Apr 02, 2020Tutor
HOW TO UNLOCK A MR1100 TELSTRA ROUTER:
HOW TO UNLOCK A MR1100 TELSTRA ROUTER: Hello, I purchased a MR1100 TELSTRA ROUTER, the seller in the sales announcement had assured that it was unlocked, it could therefore be used with any tele...
- Apr 02, 2020
I can confirm that Telstra MR1100 is not locked.
Please check the following to see whether the issue can be resolved.
1. Manually add your APN
2. Make sure the radio button in front of the newly created APN is checked. This is to set the APN as default so the device will use it to make data connection
3. On the same page, make sure Data checkbox is checked if it is empty.
Thanks
JohnPeng
Apr 02, 2020NETGEAR Expert
Thanks
Cat1
Apr 08, 2020Tutor
04/08/20
Thank you very much for helping me, following your instructions I immediately solved my problem.
Thanks again really.
JohnPeng wrote:I can confirm that Telstra MR1100 is not locked.
Thanks
