manojgupta's avatar
manojgupta
how to use wired net connection with MBRN3000 router for WiFi
Hi
I have Beam Cable wired net connection at home.
I want to use this net connection for WiFi using router MBRN3000.
How can I use wired net connection (input RJ45) with router MBRN3000, as I can see only USB input for net?
Thanks
Manoj
  • Hi Can anybody help me for using wired net connection with MBRN3000 Router. Thanks Manoj
  • Hi
    Can anybody suggest, if I can use MBRN3000 Router for wired net connection as I don't have USB modem.
    Also is it possible to user RJ45 to USB adapter for using wired net connection.
    How can I install required software for RJ45 to USB adapter.
    Thanks
    Manoj
