SteMu's avatar
SteMu
Follower
Dec 15, 2024
How turn off power mobile Router M6 when connected to power outlet and Battery is not inserted
Could you help me with a simple question?
How is it possible to Turn off the mobile Router M6 completely when the battery is Not inserted and the Router is connected to a power Outlet? Just take it from the Outlet when connected might Not be a good idea because could Shorten the life of the Router? There is no way to switch the device Off in the App and no Button for that when it is workung in Power Mode? Thanks a lot for any advice!!
  • When there is no battery, just unplug the device. No harm can be done to it. It runs off of solid state storage so it does not have to gracefully shutdown like your computer.
1 Reply
