Sorcel
Sep 12, 2023Aspirant
Http access via MR6450
We are based in France where there is no wired internet to the house. We are using a Nighthawk MR6450 to connet to the mobile cell tower (ISP: Free.fr). The MR6450 is plugged using original plugs. Th...
michaelkenward
Sep 12, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- SorcelSep 12, 2023Aspirant
Sorry for putting in the wrong section - and thanks michaelkenward for asking for it to be moved.
I have read the manuals - I have also configured other mobile hotspots before - but this one I can't find any solution to.
