Q8cracker
Aug 22, 2017Guide
I cant update my M1 device
I cant update my M1 device i donna know why i cant update my device untill now!!! also nobody here explains that and whats going on!!! my drvice firmware version still 10.12.04.04 why?
MicW
Aug 23, 2017Luminary
When you click the "check for updates" button does it state that there is an update available? If it does , make sure you have the battery in the M1 and it is fully charged so it doesn't go flat during the update.
It seems you may have to click the check for up date button a few times for it to discover the new update.Mine didn'tt find a new update until precisely one week after the last time it auto checked for an update.
The latest firmware is 10.16.04.04
- Q8crackerAug 23, 2017Guidei tried that many times
when i press on check update button it says re-check again etc...
i need more help just for understanding the real problem
best regards- DarrenMAug 25, 2017Sr. NETGEAR Moderator
You may have to contact Telstra for help if the modem is not updating.
DarrenM
