davidms1968
Aug 13, 2020Follower
I have a AC1900 n can’t set it up
Everything I try nothing seems to make a difference it won’t connect to the nbn which is HFC n half the time the genie app won’t let me in n nighthawk app say it’s not compatible with the model
1 Reply
NBN has many different types of connections. did you check with them to see if the c7000 was compatible with your service?
https://kb.netgear.com/30439/What-is-an-NBN-network-and-is-my-NETGEAR-DSL-modem-router-compatible
