dvstrideR
Jan 22, 2021Aspirant
I have a lb1120 modem connection failure
My modem tells me I need a firmware update but I cant get a connection to do the update, I have tryed to use a wireless connection on my pc but every time I connect the modem to my computer I loose c...
michaelkenward
Jan 23, 2021Guru - Experienced User
dvstrideR wrote:
...every time I connect the modem to my computer I loose connection and it would not connect,
What happens when you "lose connection"?
How are you trying to connect? What messages do you see?
