jnprice
Aug 26, 2020Aspirant
I have a situation with adequate broadband cover via fibre but no mobile reception - need a device
I have a situation with adequate broadband cover via fibre but no mobile reception on several sites- need a device for use by staff and visitors. Can you suggest anything?
Aug 26, 2020Guru - Experienced User
jnprice wrote:I have a situation with adequate broadband cover via fibre but no mobile reception on several sites- need a device for use by staff and visitors. Can you suggest anything?
Are you asking about a router or about a cellular microcell? You weren't very specific.
