mikea2060's avatar
mikea2060
Follower
Mar 29, 2024
I need a cell based hotspot for verizon service,
I need a cell based hotspot for Verizon service. It must be able to run 24/7 for security cameras and have a ethernet port. What products does Netgear have for this application?
  • I would personally stay away from the current Netgear offerings.  There are some known issues with all of the M6 versions that would make a 24/7 connection impractical.  Verizon is even worse since they're very particular about what type of SIM card and plan is being used in the hotspot.  Look into the Inseego MiFi X Pro M3100 for Verizon.
  • plemans's avatar
    why not get the verizon home service? their dedicated router is much better performing than using a hotspot
