bigpop445
Jun 08, 2018Aspirant
I need help with router netgear M1
I have a problem with the M1 router
After update to version 10.25.1.1, the wifi is very slow and when using the cable the speed is normal
The previous version did not get this problem and the interne...
mdgm-ntgr
Jun 12, 2018NETGEAR Employee Retired
Which firmware did you update from?
Have you tried resetting the system to factory defaults?
Are you using a Telstra SIM?
bigpop445
Jun 12, 2018Aspirant
1 -
The old firmware is NTG9X50C_10.12..02.01
Now the firmware used is 10.25.01.01
2 -
Yes, I did that
3 -
No I am using another telecom company
I tried more than the telecom company and the problem still exists
