yellowtao
Aug 14, 2021Aspirant
i need MR5200 connection to 5G SA (stand alone)
MR5200-100EUS,I need the 5GSA mode of routing, please support turning on the 5GSA mode in the next firmware upgrade,X55 Support 5GSA and NSA, why not support all modes from the beginning
TeeJay74
Aug 15, 2021Virtuoso
Not all features are enabled from the beginning, because testing is inadequate or incomplete. In radio access technology untested features or parameters can cause harm. Nobody wants harms, so it is better to enable properly tested features. For sure this feature is going to be enabled, but is it the next firmware update or next one, only R&D knows.
yellowtao
Aug 15, 2021Aspirant
I use it in China, and China is already in 5GSA base station mode, which makes my router unable to get 5G.
