kaovn25
Feb 05, 2026Aspirant
I recently got a Netgear Nighthawk M1 (Model: MR1100-1TLAUS - Telstra)
Hi everyone, I recently got a Netgear Nighthawk M1 (Model: MR1100-1TLAUS - Telstra) from a friend. I am looking for a solution to manually update the firmware, as the OTA function is not picking ...
Feb 05, 2026Guru - Experienced User
kaovn25 wrote:I recently got a Netgear Nighthawk M1 (Model: MR1100-1TLAUS - Telstra) from a friend. I am looking for a solution to manually update the firmware, as the OTA function is not picking up the latest version.
Device Details:
Current Firmware: NTG9X50C_10.25.01.00
Netgear Initial Firmware: NTG9X50C_10.25.01.01
Target Firmware: I want to upgrade to the latest version NTG9x50C_12.06.08.00.
I see a link in this post you could try:
- https://community.netgear.com/discussions/aircard/mr1100-nighthawk-m1-manual-firmware-update---telstra/1949065/replies/1951659
A bit older than you are looking for. But Netgear normally doesn't provide links for carrier-specific products. You could try reaching out to Telstra.
kaovn25
I have tried but it seems the link is not working
- StephenBFeb 06, 2026Guru - Experienced User
It works when I test it.
But I did need to open it in a new window, and then hit enter. Then select download from Chrome. Chrome says it is insecure, so I then needed to select "keep".
