EXaXXion
Jan 25, 2026Tutor
I solved the WIFI name problem with a factory reset
Hello, I have the same problem, I solved the WIFI name problem with a factory reset. But now I want to change the encryption to WP3 and the problem is the same, the "apply" button is disabled. Al...
EXaXXion
Jan 25, 2026Tutor
And the next question, is it possible to use the same SSIDs for both WLAN frequencies?
