Slayer2000AD
Jun 21, 2023Aspirant
I want to connect the new M6 pro to my yellow 2.4 g port on my RBK853
Am I able to connect? the new M6 pro to my yellow 2.4 g port on my RBK853 My service provider network is currently down for the next two weeks I want to be able to use this device as my current ma...
schumaku
Jun 21, 2023Guru - Experienced User
The RBR850 router models RBR850 and RBR840 provide a WAN/Internet port 2.5 Multi-Gigabit Ethernet port for
connection to a high-speed modem. This port also supports Gigabit Ethernet (1000BASE-T) and Fast Ethernet (100BASE-T) connections.
Nothing that stops you from deploying a M6 Pro, permitting the device and the router are configured appropriately;
M6 Pro admin .
Settings IP Passthrough: ON
DHCP: Disabled Ethernet Standby: Disabled
Plug the Ethernet port to the router e.g. RBR850 WAN/Internet port, and restart the router. Configure the router Internet connection for "Get Dynamically from ISP. Your ISP uses DHCP to assign your IP address. Your ISP automatically assigns these addresses."
Have fun!
- Slayer2000ADJun 21, 2023AspirantOnce my network service provider is back up and running, can I use the MR6450 as a redundant back up network.
- schumakuJun 22, 2023Guru - Experienced User
Afraid no. The Orbi router are single WAN devices only.
