Drail14me's avatar
May 28, 2021
I'M SO SICK OF NETGEAR AND THE MR1100!!!!!!!!!
Since March, THREE MONTHS, I have been trying to get the ethernet port to work on multiple MR1100ATT mobile hotspots. The ethernet port on the first MR1100 I got from ATT would not work. No matter what I connected it to, I got no internet connection and "Ethernet port not connected". I tried to call Netgear technical support but since I didn't register the MR1100 nor did I have paid Tech support, tech support would not talk to me. I called AT&T and they had me return the MR1100 and sent a replacement.
Got the second unit and tried to register it on the My Netgear site. Entered the serial number but got a message "Unable to register product to your account: Product not found". I tried the ethernet port, and NOTHING! Called Netgear Tech support again. They did some basic trouble shooting then asked if it was registered. I explained that I'd tried to register online but it would not work. They tried to register it over the phone but I was told that it would not register so they could not help me!!! I called AT&T and again, they only offered to replace.
Got my third MR1100 today. Tried to register with the SN on the My Netgear page. Again, told it could not be registered!!! Tried the ethernet port by plugging it into three different devices using several differed CAT5 ethernet cables. NONE would work.
What do I have to do to get the ethernet port to work????????????????????? What do I have to do to get it regestered where I can get Netgear to support their product??????????
    • Drail14me's avatar
      Drail14me
      Tutor
      Yes, I've had several posts over the past three months about the continued issue. No solutions or fixes offered. Very frustrating. This router is our only source of internet where we live.
      • michaelkenward's avatar
        michaelkenward
        I doubt if you will get much more than that without going into a lot more detail.
        As it stands, all you have said is that the Ethernet port is not working.
        That you have tried three different devices suggests to me that something is going wrong when you set it up.
        But we have no idea what you are doing and what goes wrong.
        Take this:
        I'm wanting to connect a laptop to it via the ethernet port but it won't work. When I go to the wifimanager to check the settings, in the Dashboard it simply says "Ethernet: Not Connected"
        What wifi manager?
        I don't know what you are doing, so I have no idea if you have read the manual, and seen this bit:
        Note: You cannot use an Ethernet connection and use a tethered
        connection to access the mobile router at the same time.
        You can keep turning up here with "it doesn't work" messages, and detailed accounts of you frustrating fights with Netgear and AT&T, but to make real progress you might like to focus on the technical stuff and forget about anything else.
