NotRealSmrt
Apr 04, 2022Tutor
I'm using the Nighthawk MR1100 for gaming and am having bad lagging issues
Can someone please tell me why i can't change my NAT TYPE on my PS5 after port forwarding on the router? It's taking the enjoyment out of the game for me
Apr 05, 2022Guru - Experienced User
did you try putting the PS5's ip address into the MR1100's DMZ?
Then go into the PS5 and see if you can change it.
- NotRealSmrtApr 05, 2022Tutor
Thank you for taking the time to reply. I just tried but it still says i have a NAT TYPE 3/Strict. Any other options?
- plemansApr 06, 2022Guru - Experienced User
Who's your hotspot provider?
Some have carrier grade nat that sets the nat level.
Did you try using a different dns provider?
- NotRealSmrtApr 06, 2022Tutor
I have AT&T 100g a month plan. I did try a different DNS setting . I usually use 8.8.8.8 Google - But i also tried the 1.1.1.1 Cloudlet DNS. Does changing the subnet mask make a difference? If my provider restricts my NAT TYPE can i ask them to assign me a stable ip address? Thank you again for your time.
