NotRealSmrt
Apr 04, 2022Tutor
I'm using the Nighthawk MR1100 for gaming and am having bad lagging issues
Can someone please tell me why i can't change my NAT TYPE on my PS5 after port forwarding on the router? It's taking the enjoyment out of the game for me
NotRealSmrt
Apr 05, 2022Tutor
Thank you for taking the time to reply. I just tried but it still says i have a NAT TYPE 3/Strict. Any other options?
Apr 06, 2022Guru - Experienced User
Who's your hotspot provider?
Some have carrier grade nat that sets the nat level.
Did you try using a different dns provider?
- NotRealSmrtApr 06, 2022Tutor
I have AT&T 100g a month plan. I did try a different DNS setting . I usually use 8.8.8.8 Google - But i also tried the 1.1.1.1 Cloudlet DNS. Does changing the subnet mask make a difference? If my provider restricts my NAT TYPE can i ask them to assign me a stable ip address? Thank you again for your time.
- plemansApr 07, 2022Guru - Experienced User
I'd try going through att. Seems like you're not the only one that's had that issue and has done everything from the hardware end.
Nighthawk MR1100 PS5 NAT Type 3 connection issue. | AT&T Community Forums
- NotRealSmrtApr 07, 2022Tutor
Thank you again for your time,i'll try through AT&T.
