Huth_S0lo
Mar 27, 2021Follower
IMEI on Netgear LB1120
Hello,
I saw your post on Netgear, and I think the solution would help resolve the problem I'm having. But your post doesnt specify the process to accomplish this. I'm guessing it requires doing a telnet to the device, and then moifying things. But I wouldnt really know. Could you add some color to this? I know that the original post is 4 years old now. But I'm hoping you can help.
Thanks,
Huth
> I saw your post on Netgear, [...]
"you"? "your post"? Where?
If you can't Reply in some old thread, then you should provide a link
to (the URL for) that old thread.- michaelkenwardGuru - Experienced User
Donning my Sherlock Holmes deerstalker and putting together the clues IMEI and LB1120 I deduce that you may be after this:
Modem Label
In addition to the default URL and password to access the modem’s web pages, the modem label on the
bottom panel shows the following information:- Serial number (SN)
- Stockkeeping unit (SKU) number
- MAC address
- IMEI (International Mobile Station Equipment Identity)
It is in the manual for the LB1120.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
If that isn't what you want, you have to say more, preferably in the right bit of this community.You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
