63holden
Mar 03, 2022Aspirant
Improve Nighthawk M2 wifi range
Is it possible to improve the wifi range of the M2 by pluging in a Wifi extender in to the usb, I'm looking for something as a portable solution so was hoping for something usb powered
Mar 04, 2022Guru - Experienced User
The MR2100 has an ethernet port. It'd be simple to connect an access point or a router to that for better range.
63holden
Mar 04, 2022Aspirant
Thanks for the sugestions but as I mentioned I was using it as a portable solution so I will not always have mains power that is why I asked about usb
Has any one used this successfully Nighthawk Dual-Band USB 3.0 Adapter(A7000)
- plemansMar 04, 2022Guru - Experienced User
The vast majority of USB ethernet adapters require windows/mac/linux to run. And those usually require installing the drivers. Not possible with this. there's quite a few travel routers that have built in batteries. You could try connecting them. But doubtful you'd get any more range than the hotspot provides.
- 63holdenMar 04, 2022Aspirant
Yes I thought it may have issues requireing drivers
