nmathews193's avatar
nmathews193
Follower
Apr 22, 2017
Incoming Port Forwarding Netgear Zing
I'm having issues setting up port forwarding on my Zing Hotspot. I setup port 1024 on the router and the security camera I'm trying to connect to. The local address 192.168.1.97:1024 works fine. The camera is also updating the dynamic url with the correct IP address as well. When I try to access the camera over the internet with either the IP address of the Zing or with the dynamic address, the page just tmes out. The settings on the hotpot seem pretty basic, so I am lost at what I should do. Thanks for your time,
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    with AirCard there is two types of network mobile originated or mobile terminated in order for yout device to accept incoming connection requests from internet it has to be mobile terminated. So you should contact your ISP and ask them about the problem.
    DarrenM
