Boo1
Apr 20, 2019Follower
Interent Connection
Have 5GHz but also need to be able to choose 2.4GHz - how can I add the 2.4GHz option?
schumaku
Apr 20, 2019Guru - Experienced User
What hardware model, what firmware are you talking about here?
Newer models make use of one SSID for both the 2.4 and the 5 GHz band, so it's up to the client to decide on the better signal.
