Boo1FollowerApr 20, 2019Interent Connection Have 5GHz but also need to be able to choose 2.4GHz - how can I add the 2.4GHz option?
additudeVirtuosoApr 21, 2019It should be in your routers WiFi configuration settings if it exists. You may need to enable 2.4 and choose a seperate SSID than the 5G....
