meloserj
Aug 18, 2023Aspirant
Internal antenna gain of MR5100-MR5200
!!!! Original post was in wrong forum, apologize admins as I can't remove or move it !!!!! Hello mates Does anybody knows how much is the internal antennas gain of MR5100/MR5200 in 4G/5G cell...
JT240Z
Aug 19, 2023Luminary
Might also want to consider that the internal antennas are 4x4 MIMO while the external ports only support 2x2 MIMO operation. This alone will reduce the device's ability to pull in multipath signals. Even the best external antenna will not provide you with greater bandwidth if the area you're in has reasonable signal strength. The external antenna will only help if you're in a very weak signal area or the location you're in is shielded and you need to get signal from outside the shielded area. Also keep in mind that the antennas you're looking at must be 50ohm and support frequencies up to 6GHz.
- meloserjAug 19, 2023AspirantTnx dude, do you know how much is the gain of internal 4x4 antennas?
- JT240ZAug 19, 2023Luminary
Don't know what the actual gain is but it really comes down to more than just gain. Can you explain why are you needing the external antenna? Might help with some decision making.
- meloserjAug 19, 2023AspirantTnx dude, at this moment I just want to know the actual gain of internal antennas. I’m making a comparison
Cheers
