afg1
Jul 11, 2020Tutor
Internet Connection Lost
I am having a frustrating problem where I lose internet connection with my LB1120 modem once or twice a day. I have it set up with a Ubiquiti Networks Router ER-X. Mobile carrier is AT&T. If I l...
afg1
Jul 26, 2020Tutor
icaruspony so I use this service for home internet. There is only the one tower near my home, so that wouldn’t work.
How do you toggle data on/off?
Does switching bands mean switching ports. How does one do that?
icaruspony
Jul 26, 2020Luminary
In the web interface there is a toggle switch for data. Someone on here even posted a python script that you can load into a separate router with entware or optware to automatically toggle data off and on when connection is lost.
By default, there are two bands: WCDMA and LTE All. On a side note, some people have used USB and telnet to add new bands to this list that will lock your device to specific band(s). That way, it can be forced to connect to the FASTEST band instead of the STRONGEST band.
