Oh1100
Jan 05, 2025Aspirant
Internet Connection with M5 Nighthawk Not possible
Hi all, entering Tunesia today and bought an Orange Tunesia SIM. M5 mobile Router Shows 4G, But i geht no internet connection. Using the SIM in the iPad, i get a Connection. But i Need the Connec...
- Jan 06, 2025
Made now a reset of the Router and pur in the APN Settings from Orange. Now ist works
rcpax
Jan 05, 2025Luminary
Did you set the correct APN for the Tunisia cell operator?
Oh1100
I think yes, because with the APN in the Ipad, da Connection works
- rcpaxJan 05, 2025Luminary
what are the APN parameters that you set? what specific carrier are you using? would help if you can screenshot the APN settings page and post it here
- Oh1100Jan 05, 2025Aspirant
Checked the APN Settings and modiefied it, But no progress
- Oh1100Jan 06, 2025Aspirant
