Jesi
Jun 13, 2019Aspirant
Internet disconnected, orange light
My dad bought this modem because we have spotty internet where I live. He's trying to get me to set this up but it doesn't seem to be working with the sim card we want to use. We tested it with a card...
W1lliam
Jun 14, 2019Virtuoso
You probably can try to insert this sim card onto a cell phone, it will update over proper APN for the phone automatically ( most of the case), once you can confirm it works, you can then check on the APN details from the phone and apply that onto your M1.
William
William
Jesi
Jun 14, 2019Aspirant
It is an iPad SIM card, so it didn’t work in the phone when I tried it. But it’s already been inserted into an iPad. Do you know the default apn settings for an iPad? I tried looking up how to see it, and apparently my carrier doesn’t allow us to see it.
Info needed:
Name:
APN:
authentication:(PAP, CHAP, or both)
PDP: (IPV4, IPV6, or IPV4V6)
PDP Roaming: (same options as PDP)
Info needed:
Name:
APN:
- W1lliamJun 16, 2019Virtuoso
If the APN information is not provided by the carrier, you probably need ot Google it and try.
Wiliam
