maeve
Aug 26, 2018Aspirant
Internet Greyed Out
I have a new router I can access the internet but I cannot change or configure the router as Internet is grayed out. I have done a factory reset but it hasn’t worked
Blanca_O
Aug 26, 2018NETGEAR Employee Retired
Hi maeve,
Welcome to NETGEAR Community!
May we please know the exact model of your NETGEAR device? What do you mean "Internet is grayed out"? Are you referring to the NETGEAR router page? Have you tried using different browser or device?
Blanca
Community Team
- maeveAug 26, 2018AspirantHi
It’s a WNR2000v5 and I have tried it on my iPad and iPhone and I have tried the genie app which will not let me login at all. I have rebooted, I have factory reset, I have cleared my cache. I have a much older router at a different location so don’t have the model but it has the two antennas and I have never had a problem. This new router is just out of the box
Regards
Maeve - maeveAug 28, 2018AspirantTo update I have now tried the router on my laptop too on Firefox it remains greeted out. Can you come back to me please if I cannot access the Internet area the router is useless to me and will have to go back and I won’t buy netgear again
- Blanca_OAug 28, 2018NETGEAR Employee Retired
Hi maeve,
I have sent you a message. Please check your inbox.
Blanca
Community Team- shadowboxDec 29, 2018AspirantWhat was the solution to this? I'm having the same problem in the same model router.
It's saying "no internet", but it's connected and allowing WiFi traffic. I suspect I need to change the MAC address but I can't do this until I can access the internet settings.
