BillBrazen
Jul 30, 2021Aspirant
IP passthrough disables data
When I enable ip passthrough on my mr1100, the screen displays "0 devices connected", even though it is connected to my PC via Ethernet, and it no longer transmits data through Ethernet. I can only ac...
michaelkenward
Aug 01, 2021Guru - Experienced User
BillBrazen wrote:
I don't understand, are you saying I should or should not enable the VPN passthrough for the IP passthrough to work?
I'd ignore that message. It is linkspam and probably a bit of meaningless text copied from somewhere.
Reported.
TL_NTGR
Aug 04, 2021Apprentice
How is the device being powered? Is USB connected to a power brick or is it connected to a different power source (i.e. PC). USB data path will take priority over teh Ethernet. Just want to make sure you problem is not caused by the USB source supporting charge and data paths as this creates the problem you described.
