davewlex
Nov 23, 2021Follower
IP Passthrough on MR5100
Can anyone describe what IP passthrough actually does? I was looking to only use the modem part of my MR5100 to get internet to my home network. But from what I read, IP passthrough is NOT the same...
LTEJunkie
Feb 09, 2022Tutor
I would also note that the phrase "IP Passthrough" is nowhere to be found in the manual! This is the manual I am using: https://www.downloads.netgear.com/files/GDC/MR5100/MR5100_MR5200_UM_EN.pdf
I guess this might be Netgear's fake feature that might only work with their own home mesh routers. How lame. This is going to go back to the seller as it's too proprietary if that is the case.
