dragonsrule10
May 29, 2024Follower
IP4 Support
Hey there, I had a MR100 router, but it didn't have any IP4 support, and I was wondering if the MR5200 does? I contacted my ISP but it sounds like they had trouble with adding one. Looking her...
schumaku
May 29, 2024Guru - Experienced User
Curious where the idea is coming from the M1 (aka. MR1100), the M2, the M5 (MR5nnn), the M6 (MR6nnn) and the likes should not support IPv4 ...especially considering the default LAN IP address is typically 192.168.1.1, it's an IPv4 NAT and PAT router built-in, ...
