w2csa
Jan 07, 2020Follower
Iphone Sim Card lb1120
I have a LB1120 coming and want to test it.
Can I take the ATT sim card from my iphoneX and use it in the 1120?
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi w2csa
Welcome to NETGEAR Community!
A micro SIM Card that is active and enabled with data service is needed inorder for the LTE modem connect to the Internet.
If a SIM card is installed and activated, by default, the modem automatically searches for and connects to your network provider’s mobile broadband network. In the unlikely situation that the modem does not automatically connect to your network provider’s mobile broadband network, you might need to add an access profile name (APN) profile.
Blanca
Community Team
