Herrgarman
Apr 15, 2022Aspirant
IPTV on Nighthawk M1
I have searched the web for a soloution to make it possible to use IP-TV with my nighthawk m1. With no success unfortunately.
michaelkenward
Apr 16, 2022Guru - Experienced User
Moved to the appropriate section.
Mobile Routers, Hotspots & Modems
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Herrgarman
Apr 16, 2022Aspirant
- HerrgarmanApr 23, 2022AspirantIs it in the future possible to change the software to make IP-TV work with this mobile router?
