thudgens75
Aug 15, 2023Aspirant
is a mr6110 compatible with Nighthawk Tri-band WiFi 6 Mesh System, 3.6Gbps, Router + 2 Satellite
Our church was recently sent a MR6110 router from AT&T We need to amplify, extend the signal and I was looking at the Nighthawk Tri-band WiFi 6 Mesh System, 3.6Gbps, Router + 2 Satellites
thudgens75
Aug 14, 2023Aspirant
Before I purchase I want to make sure this is compatible with the router I have from AT&T and what configuration will be required?
Thanks
- FURRYe38Aug 14, 2023Guru - Experienced User
The MR is a cell phone router. The MK has a router as well. Though I can connect to the MR, would be good to disable the MRs wifi radios if possible and use the MK system in AP mode for the wifi coverage and use the MRs router for internet services.
