wmic
Oct 11, 2016Aspirant
Is aircard 785 compatible with windows 10 anniversary update
DarrenM
Oct 13, 2016Sr. NETGEAR Moderator
Hello wmic
It has not been tested on windows 10.
DarrenM
- wmicOct 13, 2016Aspirant
The problem is that I have windows 10 anniversary update and I wanto to buy Aircard 785 or similar one to use it in tethering mode via USB.
I'm in trouble if the installation by usb port fails.
Do you know some similar device that is surely compatible with my operating system?
Thanks.
