Krakauer
Dec 11, 2017Follower
Is it possible to reboot the router ac785 remotely?
Hi - can anyone tell if it is possible to turn on remotely the router AC785 if it is in the sleeping mode? Or, in other terms, switch it on if you are not connected to its wifi network? For example, you left the router in a summer house at the countryside and you want to turn it on from elsewhere?
1 Reply
- DarrenMSr. NETGEAR Moderator
There is not stock setting to do that but you may be able to find another way to do it with software you may have to research that.
DarrenM
